I have been working on my old Craftsman/Roper (mid 80's) garden tractor with a B&S flat head 18HP twin engine model 422437. A lot of oil is being pushed out with great force out both breather tubes and into the air cleaner housing. So much oil that it is unusable. Oil will fill the air cleaner housing, eventually getting sucked into the carb. air horn . From there is a smoke screen out the exhaust. I am certain the oil level is not overfilled. Compression on both cylinders measure 100 psi dry. Plugs are a little carbon fouled until the intake starts sucking in the oil. Then, the plugs get coated in oil..Can there be this much blowby past rings when compression checks out at 100 psi each? There are no issues with engine sealing. Breathers are clear too. I have owned this tractor since 1986 and this issue has been getting gradually worse over time.
Any suggestions before I pull the white sheet over it for good ?
