Hi y'all. I'm new to this forum and looking for advice on oil and filters.
1. 2003 Mazda Protege5 2.0l 225k miles
2. Manual says 5w30 for -15°f to 95°f or 10w30 for -5° to 95°f, API SL OR ILSAC schedule 1 says 7.5k changes and schedule 2 is 5k changes
3.Utah, Us.
4. I do accelerate a little aggressively but not overly so. The on ramps in Utah seem to be a little short. Then I use cruise set at 69mph
5.Mostly interstate commute about 50 miles a day. (25 each way)
6. Oil consumption about 1qt per month. However I just replaced the head so I'm hoping that resolved most of that and haven't driven enough to monitor consumption
Typically I use mobil1 oil and filter I buy when on sale at AutoZone and get high milage when I can and have been using 5w30. I have been changing at 3k since I bought the car last year at 205k now at 225k. I like using full synthetic and looking to make engine last as long as possible. 2 weeks ago I replaced head, gaskets, plugs, and oil. I have amazon prime so don't mind buying oil there with free shipping but haven't yet. When I pulled the old head there was a lot of carbon build up on piston head and a decent amount on cylinder head and in intake manifold. I believe the valve guide seals and head gasket were both leaking. I know head gasket was leaking coolant into cylinder 2 and 3 and loosing compression into coolant as well. I have a new head with valves and seals installed now. There wasn't any unusual build up in valve train of sludge and was a normal color for 255k.
What oil and filter would y'all recommend and at what interval?
3.Utah, Us.
