oil analysis
North Carolina
What's a current good lab for oil analysis? Specifically for fuel dilution? I have a DI engine in the mazda, and i want to send off a sample now, and probably another in the winter time to check viscosity and fuel dilution.
Oil Analyzers. They use gas chromatography for fuel dilution measurement. Do not use Blackstone.
As I understand it, Oil Analyzers is only capable of measuring F/D up to 5%, not much better than Blackstone.
This is an example of what happens when Oil Analyzers and Blackstone measure the same oil, regarding fuel dilution:
www.bobistheoilguy.com/forums/ubbthreads.php/topics/4711386/2014_F250_6.7L,_Amsoil_SS_5w40#Post4711386
I had very similar results (posted here sometime back but cannot find right now) with Blackstone and Polaris (which I believe to be the core service used by Oil Analyzers).
Go with a service that uses gas chromatography for the most accurate results. Flash point testing is fraught with uncertainty.
When you get to 5% dilution it is time to take some type of action.
Originally Posted By: Donald
NAPA at around $16 per test including TBN or TBN.
The basic package from Blackstone does not include TBN. Always good to have.
This must be a regional or local NAPA offer. I've never seen anything like it around my area so if you happen to have a link or more info please post.
Does Napa use gas chromatography for fuel dilution? If not, waste of time for a Mazda DI engine.
