Your engine likely called for a "medium cylinder oil" this time of year...and a "light cylinder oil" in the winter...today, we would call those 40 and 20 respectively.
Without knowing the history of the engine, I would be careful using a modern oil (i.e. detergent). The issue is the amount of sludge in the engine - there are a lot of guys with original (or older restored) engines who have run them only on non-detergent oil....which leads to sludge.
So, my recommendation is a 15W40 HDEO - first, it has lots of anti-wear additives (she's a flathead, and probably has flat-tappet lifters on that cam) and second, it meets the viscosity recommendations for that vintage (and Buick would have specified it if it existed back then!)...but, because of the unknown/likely use of non-detergent, change it very frequently at first, since the HDEO will start to clean right away and this engine has no real filter...
You want to change the oil very frequently on this anyway - fuel dilution from carbs of that vintage can be severe, the potential sludge issue, and the cooler temperatures at which it runs and the condensation from long periods of not running means that moisture builds up pretty quickly too.
I used to run the Packard on 30 in the winter and 40 in the summer...but 15W40 is better in every respect than those two...especially when you're trying to start a cold engine with a 6V starter...I think you'll find that's true in your car as well.
And post some pics!
And post some pics!
