Originally Posted By: UG_Passat
late here, but my vote is smallest OEM tire size. the tire sizes are mentioned in the owner's manual. Something worth reading.
In my case, since my car came with 235/50r18 (I didn't want the 19" wheel/tire combo), the smallest OEM size is 215/65r16.
the 07 Corolla's, the biggest was 205/55r16 (S) and the ones I saw for the other trims had 195/65r15 tires.
Are you talking about tire overall diameter, or section width? The 195/65r15 has a larger OD than the 205/55r15. In general though, I think we're in agreement, the easiest conservative alternative winter tire size is to go with the narrowest section width for the smallest wheel diameter listed in the manual. And if there's a tie with differing aspect ratios, go with the higher aspect ratio to get a larger OD and more sidewall.
