In 2007, my stepmother's 2000 Camry 2.2L 4 cylinder had its original timing belt break at almost exactly 120k miles. That was the day we learned it was a non-interference engine.
The heat itself is not a problem, because the materials used in the construction of these belts can absorb it, and still function as they were designed to.I don’t think climate would matter much. Maaaybe if it’s suuuuper cold but when it comes to heat no matter the outside temp it’s right next to the hot engine which makes far more heat than some warm weather.
Run them long enough and they will break eventually.Is anyone aware of any genuine OEM Toyota timing belt that ever failed, whether it was the result of high mileage or old age? I have heard stories of aftermarket timing belts that broke, but not OEM. Of course, I don't know everything that's going on out there, so that's why I'm asking.
The tires, belts, hoses and batteries I've driven in Calgary for the last 38 years beg to differ. Tires don't dry rot, rot or crack here. Belts look new after 10+ years. Batteries last many years if they don't freeze while discharged completely. Huge temperature swings are the norm.The heat itself is not a problem, because the materials used in the construction of these belts can absorb it, and still function as they were designed to.
It's the continuous heating / freezing cold cycles that hurt over time. Taking these belts from subzero temperatures to extreme heat, (operating temperatures), is hard on them. Sooner or later something has to give.
It's the same with radiators, water pumps, and heater cores. They all last much longer in warmer climates given equal care.
The constant thermal expansion and contraction is an excellent source for creating leaks. Just as it's hard on belts by making them stiffer and more brittle.
Scotty is like a water lily, where ever the current flows he goes...I didn't know that Scotty Kilmer posted here![]()
Since you didn't mention Toyota in your post title, I'll chime in on my 2005 Caravan 2.4L (bought new). Timing belt change interval in the owner's manual is 10 years or 120,000 miles.
My OE belt broke at 99,510 miles, approximately 6.5 years from new. Clean break. Climatically, the van lived in Abilene, TX; Shreveport, LA; central California, and finally San Angelo, TX. Non-interference engine, so replaced with a full Gates kit (including idler, tensioner, and water pump). Took me about 12 hours...but I'm very meticulous and clean everything as I go.
That belt broke in two places on 14 March 2018 at 179,592 miles. Still lasted about 6.5 years, but only went round & round for a shade over 80K miles. During this belt's tenure, the van lived in San Angelo, TX; Tucson, AZ, and metro St. Louis. Replaced with another complete Gates kit.
That belt is happily humming along today at 246,000 miles in Corpus Christi, TX. My lessons learned?
1. The more I do the job, the easier and quicker it is.
2. I actually like the Gates kits.
3. I don't think I'll tempt fate past 6.5 years...and will probably do a pre-emptive change in the summer of '24, at which time I'll probably have 80K on the belt.
So yeah...they break.
View attachment 143677View attachment 143678
Are you new to cars? Under 25 years old?And a meteor could land on your car. But I've never heard of that actually happening.
