quote:
Originally posted by MNgopher:
Speaking of running 26 psi in your tires, I drove a relatives Honda CRV this week. Any guess what the recommended Air Pressure was? Surprise: 26psi, front and rear.
He he! If I ran pressure that low, the outer shoulder of my tires would be gone in no time.
I usually run 37 rear, 42 front in my Windstar, which recommends 32 all around. In general you want to maintain the factory difference (in this case zero) between front and rear pressures, but for heaven's sake, the front must have 60% of the weight and 90% of the wear on a Windstar, and you just have to run more pressure on the heavy end. I don't know what Ford was thinking with a zero differential, maybe they're assuming you run a full load of cargo all the time.
The factory recommended pressures are IMHO, minimum pressures, which give the softest ride. Also IMHO, the best indicator of proper tire pressure is the difference between treadwear in the center and the fastest-wearing shoulder (your alignment determines which shoulder wears the fastest). Ideally you would have no difference.
Back on topic, if only tangentially, your fuel economy is far more affected by tire pressure than oil viscosity. Keep 'em hard for less rolling resistance.
Fully on topic: All grades of oil flow like water when hot. The higher-vis oils provide more protection at the expense of some small power loss. Lets not forget, the wear rate is practically the same as long as there's a film between the moving parts, and anyone who believes that the film can be squeezed out easier with a XW20 than an XW30 is absolutely right. The question is, does the engine stress the oil to that point? Not if the engineers did their job right. Trust no one might be a good philosophy, especially this early in the game! But with the right EP package, the XW20 oils should be fine.
Finally, I wouldn't balk at substituting higher vis oils in any engine, as long as the shear stability and cold starting properties are appropriate for the circumstances. Echoing a previous post, heck yes, we would all run higher vis oils if we didn't care about cold starts and fuel efficiency. Why else would the OTR diesel engines run such high vis oil? For them the engine life is the most important thing.
