odd ball tire size 36x12.5r17 all terrains?
Interco makes a Super Swamper IROK in 36x13.5-17. They are bias ply for off road.
What application are you looking for? If staying with an AT tire, there are a bunch of options in 37x12.5R17
I picked up this project. It has silly skull wheels.
I got these for cheap. Has to look better than the silly skull wheels.
Putting a mini 2” lift. Don’t want a full 37 as I’m not lifting that high or adding gears.
Those came stock with 35” BFG A/Ts correct? What is labeled as a 37” should be a small step up. Look at the tire specs on the manufacturer websites. Good choice ditching those wheels
Had the same set twice… 1.) first time 2.) last time
Box of lead could not ground speed balance 😠
