I wouldn't go more than 10K on any filter...personally....BUT, it's hard to base a filters life without knowing the yr/make/model of the vehicle, and the current mileage....
here's my theory: early in an engine's lifetime you will have some sort of "wear metals" as the engine gets broken in.....as the engine ages though, provided you are using the correct oil spec'd, the wear should "taper off" per se.....so while I'd recommend a filter replacement every 3-5k during the break in period, I believe one could stretch a filter out to 8-10k after the break in (say 50k+....)
Just my theory though.
But really, it depends on the application (again, yr make and model), and the type of filter being used.....some filters are small, some are larger, offering more filter media.
