4wd
$50 site donor 2026
Return of Jumper !
I really appreciate your interest in the product. I respect your thoughts and opinions.Wait.... What? This product is added to the oil, then hops a ride on the oil, and then departs the oil when it finds a "hot spot"?
You cannot seriously believe that's how any fluid works, can you?
Well, since the entire engine will easily get over 100F, then the product will consider everything (EVERYTHING) a "hot spot". So how does it distinguish and discern where to deposit itself?
Please explain the difference between stiffness and hardness in metal alloys, relative to engine "hot spots". When a tire is low on pressure and then is pumped up, it literally changes its shape, such that deformation is minimized. How does this equate to the Militech product absorbing into metals and "stiffening" them?
What I see is that you have deeply embedded placebo bias. You use it, nothing bad has happened that you're aware of, and so it must be "working" as claimed.
Not one shred of tangible, credible, objective data has been presented by you or by the product maker. They make a lot of bold claims, and have had no 3rd party verifications I can find. And in fact, the claims about Naval use seem to be (at best) countered by some military documentation which states they DO have chlorine derivatives (despite their advertising) and they have not passed final testing, and have been dropped from consideration by the Navy, probably many years ago.
RobbS - you are free to do what you want; no one can take that away from you. It's your money and your vehicles. But you've not convinced the rest of us that this is anything but a giant rabbit hole of questionable marketing and baseless performance claims.
How many threads are you going to start on this, or mention on other threads?It's the last interval of Valvoline Restore and Protect for the 03 Ford Focus with 174k miles. Runs perfect, doesn't burn oil, everything works, works well.
It is time again to add 8 oz of MILITEC1 to the oil sump and 2oz to the power steering. Already had some in the manual transmission fluid.
This fluid is fantastic, I love it in everything I use it in at home and at work.
I warmed up the engine prior to adding 8 oz to the oil. It is a metal conditioner that is activated by heat. I went through the gears aggressively and got fluid flowing everywhere.
Runs great. Treatment I've been using on this car for decades. Love the smell, love the production.
In other words, no evidence except your testimonial. Just like the tens if not hundreds of other questionable additives with useless testimonials.I really appreciate your interest in the product. I respect your thoughts and opinions.
I've worked with this stuff for many years with success
No notible failure of any kind.
After reading your thoughts here, I have second thoughts using it again inside an engine. I've been using it on the Focus since new. The power steering pump is original and working well with 2oz MILITEC1 inside. The engine is smooth as can be, doesn't burn oil, and is strong.
Thanks for the information you provided. I wish I had all the answers,but I don't. Just stories of fun times when MILITEC1 freed up a seized motor or gave life to condemned motors.
Thanks again. To each, their own.
Ummm, this would be the last. Yes.How many threads are you going to start on this, or mention on other threads?
So if it didn't pass 9 of the 11 tests and evaluations that means it failed doesn't it? What not say so? As in use the word failed instead of didn't pass. I'd pass.It contains chlorine. DOD investigated the use of Militec1 and dropped them.
When he said that the military DID use it, I immediately thought to myself: "if it's so great why don't they still use it?"Not one shred of tangible, credible, objective data has been presented by you or by the product maker. They make a lot of bold claims, and have had no 3rd party verifications I can find. And in fact, the claims about Naval use seem to be (at best) countered by some military documentation which states they DO have chlorine derivatives (despite their advertising) and they have not passed final testing, and have been dropped from consideration by the Navy, probably many years ago.
Funny because the report also mentionsRobbS , you should have known how this would go . If you have used this product for many years and you think it has shown some benefits then by all means have at it . Trying to debate this bunch never ends well .![]()
Testimonials are among the most useless things on the planet. They are often employed by marketers since they are all they have in the absence of any real data.Funny because the report also mentions
"Second, Militec, Inc., officials expressed their view that our report does not amply convey the magnitude of customer testimonials in improving the efficacy of their product, noting that they have received tens of thousands of unsolicited laudatory testimonial e-mails from customers, and noting anecdotal commendations from veterans whom they have met. We have reviewed many e-mailed testimonials that Militec, Inc., officials shared with us, and we note them in our report. However, irrespective of their number, these testimonials are not relevant to the testing and evaluation or assigning and canceling of national stock numbers for MILITEC-1, the review of which constituted our objectives."
But, but, but... there was that time I drove some vehicle for 300,000 miles and never had an oil related failure. Must have been the Militec-1.Testimonials are among the most useless things on the planet. They are often employed by marketers since they are all they have in the absence of any real data.
April 2003: The Army, citing demands associated with the war in Iraq, requested that DLA suspend the block on MILITEC-1 and resume issuing the product for a trial period of 60 days—from May 1 to July 1, 2003. According to a Senior Army official, this temporary issuance was granted in order to assess wartime demand for the product and to address Militec, Inc., officials’ concerns that the Army was biased against their product.
