RobbS
Thread starter
It is not an oil stabilizer,Call me crazy but for some reason this reminds me of Lucas motor oil stabilizer but in a 10 weight.
Again, it's not an oil stabilizer but rather a metal conditioner. Google is pretty good.Have never heard of this product but wonder if it has molybdenum in it.
That’s not proof of anything at allI have placed it into many motors with amp draws before and after. Facts you can't deny
That is very informative. MILITEC1 doesn't contain chlorinated paraffins though .
It contains chlorine. DOD investigated the use of Militec1 and dropped them.That is very informative. MILITEC1 doesn't contain chlorinated paraffins though .
https://www.militec-1.com/what-is-militec
Geez - this could be the future of undercoatingAbsorbed into metal makes zero sense.
Metals used in cars are alloys. If things like carbon and God help us chlorine are are being incorporated into the alloy, yes it will change said alloy, and mostly NOT FOR THE BETTER!
Thank you for the information I didn't have.It contains chlorine. DOD investigated the use of Militec1 and dropped them.
Again as in other threads you've posted, I ask, how does it condition the metal?Again, it's not an oil stabilizer but rather a metal conditioner. Google is pretty good.
Miltec marketeer waves hand and says, "This is not the chlorine you are looking for."Has extremely stable chlorate esters!
“Many "metal conditioners", but not all, are derived from a chlorinated compound. The chlorine in these compounds is very reactive with a metal surface and will immediately corrode it. The corrosion byproducts and oxides then become a sacrificial friction barrier. This barrier does have a lubricating property, as it is sloughed off to expose fresh material.Again as in other threads you've posted, I ask, how does it condition the metal?
What is chemically happening to the metal?
I am no scientist. I haven't a clue how it works molecularly . Here's a posting from Google:Again as in other threads you've posted, I ask, how does it condition the metal?
Wait.... What? This product is added to the oil, then hops a ride on the oil, and then departs the oil when it finds a "hot spot"?I am no scientist. I haven't a clue how it works molecularly . Here's a posting from Google:
MILITEC-1 is a metal conditioner. MILITEC-1 simply uses the circulating oil as a means to reach the critical hot spots and metallic friction surfaces within the machinery. When the oil carries MILITEC-1 to these areas, MILITEC-1 exits the oil, leaving the oil completely unaffected and unchanged.
Well, since the entire engine will easily get over 100F, then the product will consider everything (EVERYTHING) a "hot spot". So how does it distinguish and discern where to deposit itself?RobbS said:hemically reacts with and is absorbed by the metal. The chemical reaction takes place at temperatures between 100°F and 150°F (38°C - 66°C) depending on friction and load conditions.
Please explain the difference between stiffness and hardness in metal alloys, relative to engine "hot spots". When a tire is low on pressure and then is pumped up, it literally changes its shape, such that deformation is minimized. How does this equate to the Militech product absorbing into metals and "stiffening" them?The effect of the chemical reaction is a stiffening (not hardening) of the metal surface -- approximately seventeen times stiffer when the reaction is complete. The increased stiffness dramatically reduces friction and parasitic drag, just as when an under-inflated tire is pumped up.
