I have a 2000 Civic with 16DY7 engine. I had been getting DTC P0420 a few times (Catalyst efficiency below threshold bank 1). There were no other codes. I graphed both the pre and post O2 sensors on my scan tool. The pre cat sensor switches rapidly in closed loop and shows the pseudo sine wave shape and cycles rapidly between < 200 mV and > 800 mV. The post cat is fairly flat with occasional spikes. I back probed both sensors with a DMM and recorded the min/max/avg values at 2000 rpm. The pre cat had readings of 0.890 max, 0.02 min and and average of 561 mV. Everything I have read says it should have and average of 0.450 V. The post cat sensor max 0.911, min 0.144, avg 0.722. I recorded both for about 2 minutes. I know the scan tool graphing function and the DMM are not fast enough to catch glitches or drop outs. I can't afford a scope right now.
Question: is the pre cat average of .561 too high (too rich)? Is the post cat average of 0.722 too high? I appears the post cat is indicating either the cat is not functioning or else I have an ongoing rich condition. My short term FT is between 1 and 11% and the long term is pretty constant at 5%.
Also, my IAT and ECT readings with the engine cold (not run for > 24 hours) are always 15 F apart. The cat is an aftermarket with about 60000 km on it. The O2 sensors are NGK and also have 60000 km on them. Cat was replaced over 2 years ago for the same code by my wife while I was away at school.
