Approvals, Certs, and Licenses are technical data from peer-reviewed experiments -SAE Standards and manufactures tests.It's called an "OPINION."
Then again, you seem to be running an experiment that yields "sense", "feel" and "like" as possible results. For that purpose, you don't need to pay attention to grades, certifications, etc.
API grade isn't a performance standard like SN or SP for example. Even with the Japanese vehicles it's about the license as well as a grade.The problem is that VW (or BMW or Merc or GM or whoever) wants to know the oils being used in the engines meets a minimum standard. Their standards are higher/tougher to meet than regular API standards. If they just say use 5w30, someone could grab an oil that is not VW approved, in fact that would very likely happen.
Most Japanese automakers do what you are saying. Just use 0w20, 5w30, whatever. And that is fine as long as the automaker is comfortable with plain jane API oils in their vehicles. This is part of the reason no Japanese vehicles are using a service interval of much more than about 7.5k miles (and most are more like 5k). The Euro approved oils have long life certification to 10k+ depending on the spec.
No clue. Up to you and your (butt) dyno.What about my butt dyno?
I GET ALL OF THIS!The problem is that VW (or BMW or Merc or GM or whoever) wants to know the oils being used in the engines meets a minimum standard. Their standards are higher/tougher to meet than regular API standards. If they just say use 5w30, someone could grab an oil that is not VW approved, in fact that would very likely happen.
I GET ALL OF THIS!
But, IMO, just stating XWXX, or XXWXX is so much EASIER!
Because not all xW-xx viscosity oil performs the same way. When an oil obtains a spec certification (like GM dexos, VW, Ford, BMW, etc, etc) there are dozens of testing specifications they must meet to get the spec approval on the bottle.I know this, now. But, why not just spec XWXX, or XXWXX? Why all of the numbers? Walking down an aisle of varying grades of oil weights and choose which weight you need is MUCH easier than searching the backs of oil containers for all of those numbers. Right? It seems easier to me.
In my I example, I chose the VW 502/505 as the NUMBERS I was stating. If it's so much easier this way, then why don't oil manufacturers just put the NUMBERS on the oil containers instead of the weights?Because not all xW-xx perform the same way. When an oil obtains a certification there are dozens of specifications they must meet to bet the dexos, VW, Ford, GM, etc spec approval.
Because most oils meet a spec and a viscosity grade. Both are important, and both are on the bottle of oil. Your Ford truck manual lists an oil spec they want you to use, just like every car maker. They list both the oil spec and oil viscosity they want people to use. They list a spec because not all oil performs the same in the tests that they think are important for their engines.In my I example, I chose the VW 502/505 as the NUMBERS I was stating. If it's so much easier this way, then why don't oil manufacturers just put the NUMBERS on the oil containers instead of the weights?![]()
Would you pour a jug of 10w30 lawn mower oil you had sitting on the shelf for a few decades in a new engine?? I mean 10w30 is all the same, right?I GET ALL OF THIS!
Engineers overcomplicate things sometimes. IE; FORD.![]()
And here's me thinking that most of Toyota's lineup is 10k miles.The problem is that VW (or BMW or Merc or GM or whoever) wants to know the oils being used in the engines meets a minimum standard. Their standards are higher/tougher to meet than regular API standards. If they just say use 5w30, someone could grab an oil that is not VW approved, in fact that would very likely happen.
Careful now, that stuff stinks.Would you pour a jug of 10w30 lawn mower oil you had sitting on the shelf for a few decades in a new engine?? I mean 10w30 is all the same, right?
Next time I replace my car's battery, I'm just going to grab the cheapest one. Nevermind the size. They're all 12V so they must be the same.
Smell what I'm stepping in?
Easier is one thing. Necessary is another.
My trucks engine was spec'd 5W30 originally. In 2000 they spec'd 5W20. So, I use either one of those. See how simple that is/was?Because most oils meet a spec and a viscosity grade. Both are important, and both are on the bottle of oil. Your Ford truck manual lists an oil spec they want you to use, just like every car maker. They list both the oil spec and oil viscosity they want people to use. They list a spec because not all oil performs the same in the tests that they think are important for their engines.
Your manual requires a Ford spec in addition to the recommended grade.My trucks engine was spec'd 5W30 originally. In 2000 they spec'd 5W20. So, I use either one of those. See how simple that is/was?![]()
Yes. Very few manufacturer's ever "specify" a grade.Your manual requires a Ford spec in addition to the recommended grade.
They specify a specification. They recommend a grade.My trucks engine was spec'd 5W30 originally. In 2000 they spec'd 5W20. So, I use either one of those. See how simple that is/was?![]()
You must report to Arco and get calibrations doneWhat about my butt dyno?
Yes, Grade A.They specify a specification. They recommend a grade.
Do you actually think I'm going to search EVERY container of 5W20, 5W30 oil for those numbers? That makes about as much sense as a submarine with a screen door!
Do you actually think I'm going to search EVERY container of 5W20, 5W30 oil for those numbers? That makes about as much sense as a submarine with a screen door!![]()
