Originally Posted By: dailydriver
Originally Posted By: rslifkin
The Mark VIII fan does move a bit more air than the 3.8 Taurus fan, but it's not a huge difference. Either one still moves some ridiculous (like 4000+ cfm) amount of air on high speed.
Having owned both fans, I will say there is a pretty significant difference. However, both are MASSIVE improvements over any of the aftermarket fans and will keep pretty much anything cool.
^^^WOW!!
Once either of those kicked on high, they would send my car right back into open loop,
before they had a chance to switch off!!
Let's put it this way:
I don't even have the high side of the Mark VIII fan wired in on the Lincoln. There's no point. It essentially has a slightly warmed up 302HO in it (Explorer intake, E-cam, 1.7 roller rockers, milled E7's, more compression as it was a non-HO shortblock with E6's originally so it has flat-tops..etc) with the stock rad, and that fan, with a controller set to kick the fan on at 185, and it has a 180 T-stat, will only run the fan for 30 seconds or so MAYBE in the dead heat of summer.
It is a simply ridiculous fan. If you are standing beside the car, near the doors (this is an '89 Town Car) and the fan kicks on, you will feel a huge rush of hot air (and whatever is on the ground, dirt, dust sand...etc) hitting your legs coming from underneath the car. And this is on LOW!!!!!!
