JHZR2
Staff member
I have a 98 chevy s-10 with 4.3L V6. 49k miles, driven pretty easily.
This weekend, we took a road trip. I had gotten in LC/FP and was excited. I added some LC to the oil, and added the correct first time dose of FP to the gas (and made sure it all got washed down the filler tube into the tank, so all was well-mixed). I used conoco 'top tier' gasoline.
Drove a variety of speeds, high throttle, easy throttle, cruising. At the end of the day the slightly rough idle (may be due to something else) didnt go away, and my MPG didnt increase, despite going a more optimal speed for most of the trip than I usually drive (spent many miles doing 50-55 instead of my typical 65-70).
So, I can't say that I noticed any sort of difference. Maybe it was a bit peppier with a bit heavier foot, compared to usual, but I couldnt say that with any degree of surity.
I think my rough idle may be due to a slight air leak or an EGR leak. I mainly want to use FP to keep that stuff clean and clear. And I think that will work. More importantly, I want the lubrication of all the systems. However, I cant as of now say that the claims of better MPG or drivability can be substantiated. Ill try in my 91 BMW and see what happens...
I'm not saying that I don't believe in LC/FP. used oil analysis really show the benefit of LC, and there are pleanty of tests and good mentions of FP on here. I will keep using it, as I know from my experience with MB diesels how valuable a fuel additive can be. But I just want to know:
Is it typical that even with the first time dose (2oz/5gal.), that it takes a while before benefits are realized?
Thanks,
JMH
[ October 12, 2004, 10:32 PM: Message edited by: JHZR2 ]
Thanks,
JMH
