Nokian was not always known for its snow tires. That is what marketing does: "first snow tire," etc.
20-25 years ago, you could not identify them on the European market, which is by far the largest snow tire market in the world. Even Bridgestone, which is a household name here, was always a mediocre performer there and, actually, still is.
Nokian was present in their local market. The reason why they were mediocre performers is that the largest snow tire markets have very complex demands around performance, and Noakian was never good at delivering in every category. That cheating scandal happened during that over-the-top marketing push, and they desperately wanted to take away market share from manufacturers that "own" the European winter tire market: Continental, Good Year, Michelin, and Pirelli.
Viewing pleasure?
Michelin in Europe was always good perfomer, but not as good as Continental and Good Year. Good Year was absolute king in 1990’s and up until 2005/6. But Continental pushed it out.That's some good history there, thank you!
I've never been a fan of Pirelli, but maybe because it's not a popular tire around my area? I likely should have just gone with the Michelin's. Maybe I'll stick with the Nokians for now since winter is almost over, but Iowa sometimes throws some curve balls. haha
I suppose I expected more. Maybe the tires are fantastic and it's the vehicle dynamics that are mediocre? I don't know? If I had another vehicle to swap them on to try out, I would love to.
Do you have visible rear toe in and rear negative camber? My Focus did the weird back end shimmy on grooved road with whatever tires I had on and the same thing on patchy ice in the winter with new blizzaks. My regular mechanic said it was in spec(barely) so I took it to an alignment shop and told him to do the very minimum rear toe in and keep a little rear camber.Curious what people think of the new Nokian Hakka R5 SUV tires?
I have them on our 21 Subaru Ascent and they replaced a set of Nitto SN2 winter tires that I sold to a buddy of mine. I only had the Nittos on for 5-6k miles and they had winter great traction. But would track with the lengthwise grooves on the interstate and would sway back and forth as it follow those grooves. That was a really un-easy feeling when the road was partially snow covered without knowing if it was the grooves in the road or loosing traction on the snow-covered portions causing the sway. The Nokians on the other hand are fantastic on dry roads and very quiet. But I'm on the fence for winter traction?
Car tracks straight now in grooves, broken pavement on one side only, and patchy ice. Maybe slightly more neutral handling on dry pavement, but that's a fine compromise for me anyways.
It sounds to me like your rear toe in has the rears fighting each other for grip in the snow and so break away easier than the fronts.
IMHO, the factory alignment ranges can allow too much toe in and rear camber which when near the maximum together makes a nervous rear end on snow and ice. Get the read out anyways, then you know what you've got instead of "in spec".I've seen good things about the Conti's too, but they aren't available in my size. We had the Goodyear WRT Ice on our 12 Fusion and those were horrible, barley better than the General RT43's we had for summer use. Not saying Goodyear can't make a good tire, but the only one I have liked is their Duratracs.
I haven't noticed any excessive toe or camber visually. My dealer has a camera/laser system (Hunter Quick Check) that measures alignment and tire condition when pulling into the service lanes and showed no issues. Apparently that system is more accurate than I would have imagined after talking with one of technician friends who works closely with a Hunter rep. Pretty cool system.
Anyways, I haven't had the alignment checked since new (now 32k) and it probably wouldn't be a bad idea. Can't say the factory is perfect every time too. Though when I had the Nitto's, the car had less than 1k miles when I put them on and had issues with them tracking weird. I have seen rear toe affect handling in weird ways back in my technician days too. It might be worth having an alignment done anyways just to make sure everything is up to snuff.
GY doesn’t bring stuff from Europe here. Occasionally some models. WRT was not available there.I've seen good things about the Conti's too, but they aren't available in my size. We had the Goodyear WRT Ice on our 12 Fusion and those were horrible, barley better than the General RT43's we had for summer use. Not saying Goodyear can't make a good tire, but the only one I have liked is their Duratracs.
Because a photo of two ordinary looking wheels and two ordinary looking Subaru's does not constitute pleasurable viewing in most people's book.Sure, why not? People like pictures and sometimes a picture can produce logical responses based off something someone notices that I could have looked over.
R2’s were probably made in Russia. Nokian loaded all their molds and inventory onto five container ships and shut down the Russian factory a few months after Russia invaded Ukraine again. They had huge market share there.As for Nokian, as I stated numerous times, it is IMO a second-tier manufacturer. They always lack something. R2 had really good ice and snow performance but was horrid in dry and actually dangerous in wet. They were impossible to balance without a ridiculous amount of lead, and the noise and comfort were like having A/T tire.
I am sticking to Michelin, Continental, and Bridgestone from now on. Done with experimenting. I would not mind getting Nokian R5, but as long as the price is equal to performance and quality.
The problem with them is that they are doing 1-2 things good. Rest is mediocre or horrible.R2’s were probably made in Russia. Nokian loaded all their molds and inventory onto five container ships and shut down the Russian factory a few months after Russia invaded Ukraine again. They had huge market share there.
Nokians are now made in USA.
My experience is very much opposite. We bought many, many Nokian winter tires for our fleet cars since 2005 (Hakka R), but usually Michelin for rest of year. We tried the Nokian Ones and found them equal or better for dry and wet road handling, braking and noise. We buy them if available.
When was the last time you bought a Nokian tire of any sort?The problem with them is that they are doing 1-2 things good. Rest is mediocre or horrible.
Simce they are made in US, price is resembling quality better. Before they were definitely overpriced and their marketing tried to push it as top tier tire. They are far from it. The high price was probably consequence of import from Russia.
4yrs ago. Kumho category.When was the last time you bought a Nokian tire of any sort?
What vehicle?4yrs ago. Kumho category.
As I said, they work fine in 1-2 disciplines.What vehicle?
My daughter had an Outback in CS last four years with (most recently) Hakka R3’s. She skied over 100,000 vertical feet last season and they worked great.
No for Tiguan. No, people fall on marketing.So you bought them because of their marketing? For a VW Atlas?
Here is the 2023/2024 Scandinavian test of studded and studless tires, from NAF/MOTOR magazine/ViBilagare:....Haven’t seen the Norwegian test for this season but....
Nokian's newest studless winter tyre, the HKPL R5, picks up the most points of all in the test rounds on snow and ice.
The tire has sharp reactions and steers well into the bends. Being a soft friction tyre, it offers driving pleasure, with a co-steering rear section that is well suited for active drivers.
And vice versa: Those who want a calm and undramatic tire may find this Nokian tire a bit too skid-friendly.
On tarmac, it passes the evasive maneuver test well, but it has a somewhat non-linear steering feel.
The wet grip properties are somewhat behind the best competitors, and so are road noise. R5, on the other hand, has low rolling resistance.
The Nokian is suitable for those who prioritize winter road qualities above all.
Plus:
Class-leading winter grip, low rolling resistance.
Minus:
Braking on wet roads, steering feel on asphalt, road noise.
