Hi all:
1991 Nissan Stanza 2.4L L4 100,450 miles
I had a leaking power steering pressure line, which would require the reservoir to be filled about once a month. During this time with the leak (about 2 years - I know, should have fixed sooner...), I used Valvoline Synpower Synthetic Power Steering fluid with conditioners and stop leak, never realizing that the system actually required Dex ATF Fluid...
So, about two weeks ago, I replaced the hose. Right before that, the hose really started leaking, and upon getting back from the parts store, had just finished the last of the P/S fluid from the reservoir.
So, I replaced the hose, and the suction hoses, but not the return hose (looked to be in ok shape, and cost $25 to replace, and the parts store did not even have it in stock). I filled the system with Mobil 1 Dex ATF, and proceeded to bleed the system (cap off reservoir, turn steering wheel both directions several times).
The washers at the top banjo bolt were leaking a little, and I thought that this was causing my noise (Autozone said that the system could be sucking air from the leak, and that would make the noise). So, today I replaced the washers, and bled the system.
So far, no leaks, but the steering is really noisy. I went back to Autozone, and they said in their opinion that the belts and P/S pump were ok, and not the cause of the noise. They said that the Rack could be going out.
The one other problem is that the cars pulls to the right. Going 35MPH, you could change lanes without trying in under 10 seconds.
At this point, I am looking for any and all insight into the matter. What is wrong with my steering?
Thank you.
David
Thank you.
David
