2013 Charger 5.7L; problems after sitting for years
North FL
Got a 2013 Dodge Charger 5.7 R/T I got that has been parked for a few years. Now that I am trying to get it on the road it seems when I fix one thing, another thing breaks.
Repaired the power steering pump, got a wheel speed sensor light.
Got the fender painted, looks ok, got a TPMS light.
Got the wheel speed sensor replaced, a/c now needs a 'humidity sensor' to stay on recirculate.
Drove around the block, came back to a fluid leak that wound up being a leaking hydraulic motor mount.
Got the coolant changed. Installed a new radiator cap as the old one was hissing a little, yesterday is started leaking coolant at the upper radiator hose to radiator connection.
(edit - MOD)
Bummer. Hopefully you will eventually be able to get it all sorted out.
One thing is for sure. Cars do not like to sit idle. I'm a firm believer that many problems can be avoided by regularly driving a car, even if it is only weekly.
Which color? Does it have the wide R/T stripes down the side?
Silver, no tint, 245/45/20 tires, The woman who owned it got frustrated after the powersteering stopped working. Sat for 2ish-3 years. Still has the old fuel, I replaced the battery and found the glove box light killed the old battery, so, that has no bulb in it now. It really drives well, just a bunch of silly things. The cooling system was ok when I got it but I am certain it was never changed and I did a coolant dump along with opening both block drains. A/C works fine, just needs that humidity sensor.
This a project, and I have had several projects over the years.
If this was a Honda or Toyota you wouldn’t have all these problems.
Just kidding. 🤭 LOL
Fix the small problems and keep that Charger.
Right on!
Weatherstrips OK? No mouse nibbled wiring....
Were there several styles of wheel? Tires OK?
Weatherstrip is great. Wiring works, no squirrel damage. The driver's side window down button gets sticky and needs cleaning or replacement. It will go up and down fine once you stand on the switch. Unfortunately it has aftermarket wheels that contribute to the vehicle that would be preferred by what OilStainedNapkin refers to as 'urban youth'. The tires are fine, a tad dry from sitting. Left rear TPMS has to be replaced.
I also will open another can of worms and do a transmission filter and fluid change soon.
Pic of the sled!
