Guys, my Civic is making noise that I think could be either exhaust piece being loose, perhaps clutch?, or backing/skid plate behind the front discs. It almost feels like CV joints, but it's not quite the same and some bad CVs were replaced over a year ago.
It only happens in gear, while making a turn and accelerating through the turn at low RPM/low gear(just happen to be in 2nd mainly when this occurs)/light to normal throttle.
Not sure what a throwout/release bearing going bad would feel like. This is my first manual/stick. It is hard to shift into first in this car at times, even at a stop. I had always associated this(shifting) to worn synchros, but I believe the clutch needs replacement soon anyway.
Basically, the situation originally outlined generates a 'put, put, put' noise(lower/sub end) that isn't present at idle with the engine nor from simply revving the engine while in neutral; only while driving the car in gear and turning(though the sound continues once out of the turn for a few seconds or disappears if you go to WOT). Someone suggested rod knock, but I don't think so.
Tried moving the exhaust heat shields, but they "seem" secure, but haven't checked the piping under the car for play movement. Lastly, I had visions of an engine mount being worn, since it appears to be making the sound relative to higher torque.
Thoughts? Thanks.
Thoughts? Thanks.
