Originally Posted By: The_Eric
Do you have heat now?
Nope, it has to be the 'switch' in the dash. It's next on the to-do list.
Originally Posted By: meep
OP may not have other leaks, but multiple problems tend to hide each other... Need an accurate thermometer to check engine temp. NOT the dash gauge.
Agreed. Multiple problems did try to hide each other. And the dash gauge is pretty vague.
Originally Posted By: SHOZ
Again it is almost impossible to have trapped air in a system that has the pressurized coolant tanks. Only if the level is too low and then the tank would be empty.
Prior to touching the car at all, it was very low on coolant. Only a few teaspoons of coolant was in the tank. Then I swapped the intake, that probably compounded the situation. If the air could move, I agree it should evac itself. But if it was trapped somewhere...
Originally Posted By: Vikas
- Car is NOT overheating
- Plenty of heat in the passenger compartment
- Coolant level is not dropping
So please tell me what is the problem?
Nobody ever said I had heat in the passenger compartment. I still don't. The only mention of heat was when I was referring to the cooling system under the hood:
"So if the system holds pressure, the cap is proven to be good, the thermostat seems to be working properly, and heat (but not pressure or flow) is being distributed throughout the system, what is wrong?"
