quote:
Originally posted by mailman74:
calling gary allan
syn_all_the_way
Just go to Wix and punch in those numbers and see what the xref engine pumps out.
wix
Here's the short one in WIX
Part Number: 51365
UPC Number: 765809513655
Principal Application: Ford (92-97), Honda (00-06), Infiniti/Nissan (95-06), Mazda (97-06), Mercury (91-96), Saab (05-06), Subaru (88-06), Cub Cadet, Yanmar, John Deere, Kawasaki, Kobelco, Outboard Marine Engines
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.577
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=15/22
Burst Pressure-PSI: 300
Max Flow Rate: 9-11 GPM
Nominal Micro Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.233
Here's what Baldwin pukes out for the long one
PART NUMBER: B1402
Descriptions : Microlite Lube Spin-on
Contains : Anti-Drainback Valve
14 PSI By-Pass Valve
Fits : Dodge, Eagle, Ford, Infiniti, Mitsubishi, Nissan, Plymouth Automotive
Replaces : Chrysler MD135737; Ford F32Z-6731-A; Mazda JEYO-14-302; Nissan 15208-31U00
Thread : M20 x 1.5
O.D. : 2 21/32 (67.5)
Length : 3 1/2 (88.9)
I.Gskt : [1] Included
Related to : B1400 (Short Version)
B1431 (Long Version)
WIX has no B1431 xref, IIRC. (longer)
PART NUMBER: B1431
Fits : Mitsubishi Automotive
Replaces : Mitsubishi AW343979, MD352627
Thread : M20 x 1.5
Length : 4 (101.6)
Related to : B1400, B1402 (Short Versions)
[ September 02, 2006, 10:02 PM: Message edited by: Gary Allan ]
