Nissan Matic D vs Dexron III
Caribbean
These two are similar?, for my transmission i used Dexron III but the nissan recommended is Nissan Matic D. The mechanic said that its okay to use Dexron III.
Are these 2 ATF the same?
yeah.......only in the us oil is cheap...for the rest of the world its expensive. A quart of maxlife atf is 70$
Matic-D is just gussied up Dex III; nothing special. A syn ATF will probably serve you well with the heat down in the Caribbean.
Nissan-Matic D is just Dexron III
See if you can find Pennzoil Platinum High Mileage ATF. It's really good Dex III compatible fluid and is certified to be able to replace Nissan Matic-D. I would not use Maxlife in that application. Maxlife is more like Dex VI. It's a thinner viscosity.
And within a few thousand miles Dexron III will be thinner than Maxlife ATF.
