Originally Posted By: A_Harman
Thoroughly read VG30DETT's saga over in the Racing Oils section.
He was dealing with oil starvation under high cornering G's, but also got into a pattern of failures when he rebuilt the engine by only polishing the rod journals and putting in new bearings. If the engine is built with the wrong fits and clearances, no oil selection is going to make it live.
I recommend that you do not try to rebuild the engine by polishing up the old stuff, especially if the bearing failure has blued the crank and/or rods. I don't know what the supply situation is for older Nissan V6's, but buy a rotating assembly from a reputable remanufacturer that has a warranty. Then measure all of the fits and clearances before assembling the engine. Don't put it together until you know that everything is within Nissan's engine build specifications.
As for trying to improve on the stock engine, the Nissan V6 seems to require a larger-capacity oil pan, so a 6 or 7-quart unit would probably help a lot.
I gutting out the entire motor and rebuilding with forged rods, pistons and crank this time around.
