This one has me stumped. Have a cheap night light you just plug in the wall, no on or off switch.
Seems anytime you unplug it from the outlet and then plug it back in, the bulb is burned out.
This has happened multiple times before.
Wanted to use the outlet tonight for a couple minutes and it happened again.
Wondered before I did it, will the bulb be blown? Sure enough, had to replace the bulb.![Unsure :unsure: :unsure:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
