Transmission lines aren't high pressure like brake lines so you can cut out rotted sections and replace them with a rubber line. But you could use galvanized steel, stainless steel, Nicopp, aluminum, or rubber. For transmission lines a lot of cars come with aluminum since it resists corrosion, is light and bends and flares much easier than galvanized or stainless steel.
