Iridium is the best. i use ngk in my mitsubishi, but for the impreza subaru, changing plugs is awkward, so i use Champion
Iridium long life: the ground has a piece of platinum, and the electrode has a nice wire like piece of iridium which is excellent. i gap them very carefully, to be sure not to damage the electrode, and i check with the feeler gauge, because a wire gauge doesn't work too well with such a tiny electrode. i also align the ground, because the piece of platinum is not always in the same place, so i twist the electrode for perfect alignment, and then i take a little time to make sure the gap is on the tight side, to allow for "wear" or vaporization of the ground/electrode, of which there will be very minimum, and basically this means that you change the plugs when it's time for a timing belt change, once every 160,000 miles. it takes me about 10 minutes to properly align a set of four.
