32 oz container from Amazon.
and get one of these to dispense 1 oz pours for dosing.
$1000 for washer fluid. No, just no. Not ever.
Nextzett actually doesn't recommend distilled water.I buy a gallon of distilled water and the small bottle of mix. It lasts a long time although when I put a dab of the concentrate behind my ears and on my wrists, it doesn't last as long.
Same. Love the smell.I buy a gallon of distilled water and the small bottle of mix. It lasts a long time although when I put a dab of the concentrate behind my ears and on my wrists, it doesn't last as long.
Interesting...did not know. Always have used distilled with it.Nextzett actually doesn't recommend distilled water.
Adjust ratio based on water hardness. We don't recommend using distilled or soft water (unless you're only option is well water) because the water conditioners in Kristall Klar will cause excessive foaming and smearing.
Agreed.Gummi pflege is the bomb for door seal conditioner, particularly if you have a convertible:
Gummi Pflege Rubber Care Stick
Gummi Pflege Weather Seal Conditioner Rubber Care Stick restores and revives dry weather seals around doors, sunroofs, trunk and hood lids, and convertible topsnextzettusa.com
Does this one have water repellent property? I like Rain-X but it doesn't clean the windshield well. I have to clean it once a week.
