Newbie wanting oil recommendations
Quote:
1. I drive a 2017 Subaru WRX
Originally Posted By: SR5
OP is that "SN AND GF-5" or is it "SN OR GF-5". ?
Originally Posted By: SonorousAria
Btw, in response to your question, the manual clearly stated “or.”
Excellent !! That "or" opens you up to some good 5W30 oils that are API SN (but not GF-5).
As Garak said, a Euro oil that is rated ACEA C3 as well as API SN would meet your requirements, but is also a lot stronger (higher HTHS) and thicker (higher KV100) than a typical GF-5 (resource conserving) oil. BTW most GM Dexos2 oils (not to be confused with Dexos1-Gen2) are effectively C3 oils.
For example Mobil1 5W30 ESP
KV100 = 12.1 cSt
HTHS = 3.58 cP
SA = 0.6 %
It's API SN and also ACEA C3, dexos2, BMW LL-04, MB 229.51 and Porsche C30
https://mobiloil.com/en/motor-oils/mobil-1/mobil-1-esp
This oil has higher HTHS but is low-SAPS (low SA%, & TBN) so it's not for a long OCI (oil change interval), but it should easily do 6k miles.
The Shell Rotella Multi-Vehicle I mentioned before has a higher TBN (to fight acid build up in the oil) so it should be good for 10k miles if not more. But I suspect your OCI will be limited by warranty requirements anyway.
Both are quality, name brand, full synthetic, 5W30 API SN oils.
