Newbie 1st Post : 5w30 vs 10w30
Hi,
I think 5W30 has the energy starburst symbol. It probably gives better fuel economy. I used to use 10W30 in the winters and 20W50 in summer for my high volume, low pressure oiling 86 Jetta.
In your case, I would use 5W30 in the winter and 10W30 in the summer. Toyota has major sludge issues in their cars. If your engine is one of those, synthetic may be a very good idea.
W115nut
quote:
Originally posted by Va Runner:
Just purchased a new 2006 4 cylinder Toyota & the owners' manual recommends the use of 5w30 oil. In fact, Toyota discourages the use of 10w30 oils.
I have never used "5W" oils as I viewed them as being too light and not necessary in the mild Virginia climate.
I've read in numerous forum posts about members preference for the "5W" oils over "10W" oils. Can someone explain why the 5W oils are preferred and how the viscosity compares to 10W oils?
I will be changing my Toyota;s oil for the first time at 500 miles and need to select the oil soon.
If I utilize conventional oil, which brands are preferred and why?
Thanks in advance for your explanations and suggestions.
I like amsoil series 3000 its a thicker 5W30 for diesels and gas engines as a matter of fact lastnight i did a change with a amsoil eao oil filter and go to 10k change interval then do a used oil analysis but since your under warrenty and plan on going sythetic find a good blend then after that go to a fully and enjoy your ride.
