- Joined
- May 19, 2024
- Messages
- 6
Hello all, first post but I've been gleaning lots of info over the years from BITOG. Anyway, my latest order of filters from RockAuto is completely different from what I expect in Wix. So different that I'm debating whether I even want to use these or if I should send them right back.
First off, the filter is of completely different construction than the last batch I bought of the same model. The inlet holes are fewer and inside it's got a plastic cage instead of the steel perforated tube. The threaded plate is held on by bent tabs and sealed with a thin rubber washer. The bypass valve spring is also secured by bent tabs which released with disconcerting ease when I went in with a pick. The ADBV is white, which I've never seen before. I'm not sure what it's made of.
There is also rust inside the filter housing as you can see in the pics.
The filter is a 51348. Stamp on the bottom reads "062023 GN 01". Made in China by Mann + Hummel. Wix logo is stamped on the side in white, no sticker. The filter arrived sealed in plastic shrinkwrap inside it's Wix-liveried box.
Incidentally I received a damaged filter in my previous batch which I dissected a few months ago so I have a comparison. I've included three pictures of it. They're the ones with the red ADBV, the steel core tube and the spot-welded drainback spring retainer. It was perfectly clean inside the filter housing with no rust. It is also a 51348. That one is made in the U.S.A.
My initial reaction is to send the remaining five filters back and switch to a different brand henceforth. My question is, am I overreacting? Has anyone else had issues with this new style of filter? Is the rust acceptable at all?
Thanks,
Ivan
Thanks,
Ivan
