I have the cobras with those comfort grips, love them.I spent $38 at Amazon for a pair of 9" Knipex pliers
My old 8.5" Channellocks will get transferred to the tool kit I keep in the car.
In this "test to failure", the Snap-on and Tekton 3/8' ratchets tied for 1st place. Both had the anvil shear off at 292 ft-lb, with no apparent damage to the internals ( no tear down inspection was performed).I've been very happy with the TEKTON ratchets that I have. That slender head has allowed me to get into some tighter spaces that others that are just slightly thicker would not.
At the start of the the group test, the Tekton was taken up to 680 ft-lb ( ! ) with no internal damage being felt, and no anvil shearing, but the handle was badly bent. Assuming the Quinn torque adapter readout is accurate, this is amazing. The Tekton was the only ratchet of the test group that was subjected to maximum force twice, first at 680 ft-lb, then later at 292 ft-lb.
It would have been nice to see them test the Hazet 916HP. They can handle quite a bit of torque.+1 Definitely an outlier, no 3/8 drive ratchet I have ever used can handle almost 700 lb.ft
I watched the two videos some time ago, the second one the Milwaukee wins at 300 ft lbs. It’s more entertainment than anything else seeing tools breaking. He breaks the anvil for the most part, so what is that? The Husky was impressive since it is quick release. Then flex handles are thrown in, the Wright broke the hinge pin. Means nothing at all, these are 3/8, not meant for this use. The 680 ft lbs was like a reading jump as the handle bent. How he straightened it then went on to get 292 on the anvil, never 680, is a mystery. The 680 had to be a fluke reading.+1 Definitely an outlier, no 3/8 drive ratchet I have ever used can handle almost 700 lb.ft
Nice looking vice grip, the teeth look deeper and larger than some.View attachment 100359View attachment 100360View attachment 100358
New tools yesterday. Slack adjuster tools. Need those for my dads truck adjusting the slack adjusters. Probably could of gotten them somewhere else cheaper but he had them and rarely does so I figured I’d get them now. Replacement 13mm socket and a pocket Phillips head screwdriver. Replacement 7 inch straight jaw locking pliers. Mine the chrome started peeling on the third use. Was somewhat disappointed about that. Hopefully won’t have the issue again.
Yes they are really nice. I love them. Other than the chrome issue they have been perfect. I usually round teeth off of them but these haven’t shown any signs of that.Nice looking vice grip, the teeth look deeper and larger than some.
You are correct, it has zero to do with quality, no one I know could put even 200 lb.ft on a 7" 3/8 drive ratchet without a pipe and the tool was not made for that. More important is the back drag, the amount of play in the mechanism before it catches the next tooth and smoothness of the mechanism.I watched the two videos some time ago, the second one the Milwaukee wins at 300 ft lbs. It’s more entertainment than anything else seeing tools breaking. He breaks the anvil for the most part, so what is that? The Husky was impressive since it is quick release. Then flex handles are thrown in, the Wright broke the hinge pin. Means nothing at all, these are 3/8, not meant for this use. The 680 ft lbs was like a reading jump as the handle bent. How he straightened it then went on to get 292 on the anvil, never 680, is a mystery. The 680 had to be a fluke reading.
I also thought the 680 was some form of reading jump because as I recall (and I, honestly, don't care to spend my time reviewing a second time) it was very sudden. That, IMO, would call into question the continued accuracy of his fancy Harbor Freight meter if this were a true scientific test.I watched the two videos some time ago, the second one the Milwaukee wins at 300 ft lbs. It’s more entertainment than anything else seeing tools breaking. He breaks the anvil for the most part, so what is that? The Husky was impressive since it is quick release. Then flex handles are thrown in, the Wright broke the hinge pin. Means nothing at all, these are 3/8, not meant for this use. The 680 ft lbs was like a reading jump as the handle bent. How he straightened it then went on to get 292 on the anvil, never 680, is a mystery. The 680 had to be a fluke reading.
Stahlwille have worked exceptionally well for me. That precise open ends allows you to use the combination wrench where you can’t get a flare nut wrench.Stahlwille wrench set. 18 mm opening reads 18.16-.17 mm. I measured my Wright and it was 18.29 mm. I was careful to try for a lowest firm reading. For the price of $78 plus tax for the set 6-32 mm and very nice fabric type case isn’t bad. The closer fit on the open end lessens the need for fancier off loading notches imo. They know what they are doing. View attachment 100354View attachment 100353
The price went from $78 to $203 on Amazon. But AZ can be up and down.Stahlwille have worked exceptionally well for me. That precise open ends allows you to use the combination wrench where you can’t get a flare nut wrench.
I just did a set of brake hoses on an 18 year old Volvo from Illinois (road salt, considerable corrosion on the nuts and fittings).
The Proto flare nut wrenches that I have would not fit because of clearance on body parts, suspension parts, etc. Had the same problem with crowfoot flare nut wrenches.
The Stahlwille 13mm combination wrench fit tightly, and removed every fitting with no drama. No rounded fittings.
Truly great wrenches.
That’s shocking. I’ve bought from Zoro, from Mr. Worker and from Amazon.de - you might give those a try.The price went from $78 to $203 on Amazon. But AZ can be up and down.
I watched the USA site. It was about $78 for a long time then went into 80’s. Then I decided to get one when it was $78 again. I think something was wrong with the pricing because $78 shipped from Europe is too cheap. Being grey market it won’t have any warranty in the US. I don’t care about that. The deep offset wrench set has gone up too, not as much, but still a bargain for what it is. The price will probably go back down, not sure what is going on.That’s shocking. I’ve bought from Zoro, from Mr. Worker and from Amazon.de - you might give those a try.
Using Chrome to browse Amazon.de gives you auto translate from German.
Sign up for Amazon prime for the month (it’s 8 or 9 euro) and save the shipping.
I bought my Stahlwille from Amazon.de a couple years back.
