Im the new owner of a tired 2008 4runner with 220K miles. Engine purrs like a kitten. What is a reasonable OCI using FS? If it helps, I do all my own maintenance, when I can, and certainly all fluid changes.
Did you post photos of your engine with the oil pan off? I'm vaguely remembering a similar oil change history for that post.MX manual says 5,000 miles.
The 1GRFE in my 07 FJ Cruiser still runs like new and doesn't consume any oil w/238k miles, and gets the same gas mileage it did when we bought it in Jan.09.
Here's my OCI history:
Dec 2010 = AMSOIL Signature Series 0w30 - 17,000 miles
Dec 2011 = AMSOIL Signature Series 0w30 - 18,700 miles
Aug 2012 = Amsoil AMO 10w40 - 12,200 miles
May 2013 = Amsoil AMO 10w40 - 14,000 miles
Mar 2014 = Amsoil AMO 10w40 - 15,000 miles
Nov 2014 = Amsoil ACD 10w30 - 14,200 miles
Jul 2015 = SuperTech Syn 5w30 - 10,100 miles
Apr 2016 = Mobil 1 5w30 - 11,000 miles
Aug 2017 = Mobil 1 5w30 - 13,000 miles
Oct 2018 = Mobil 1 5w30 - 14,500 miles
Sep 2019 = Delvac1 ESP 5w40 - 11,000 miles
Oct 2020 = Delvac1 ESP 5w30 - 11,100 miles
Jan 2022 = Delvac1 ESP 5w30 - 10,000 miles
Mar 2023 = Mobil 1 5w20 - 6900 miles
Sept 2024 = SuperTech 5w30 & VPB ”Restore” 10w30 – 6000 miles
June 2025 = Valvoline Restore and Protect 5w30 – 5000 miles
If you find it doesn't burn oil go through your stash first. If you see that it burns Valvoline Restore and Protect would be good.Thanks for the replies. The first thing I did was change the fluid in the diffs and transfer case, full (12 quart) drain and fill on the transmission, and full drain and fill on the PS system. Coolant was done recently by dealership (I have receipt). Only fluid left to do is the brake system.
Luckily, all the 4WD systems engage (4HI, 4LO, center lock, etc).
Ill give Valvoline Restore and Protect a look. I have loads and loads of 5w30 though. So Ill need to go through that all first.
Nice. Power steering often overlooked by many. I've had to replace my steering rack so I unfortunately I got fresh PS fluid that way.Thanks for the replies. The first thing I did was change the fluid in the diffs and transfer case, full (12 quart) drain and fill on the transmission, and full drain and fill on the PS system. Coolant was done recently by dealership (I have receipt). Only fluid left to do is the brake system.
There's an argument to be made that HDEOs are not good for gasoline engines.For a long while I used Mobil 1 0W-40 only, for all cars I own and other family cars I maintain. No complaints, great oil.
Then I switched to HDEO: Mobil 1 Delvac 5W-40. Also no complaints, but I liked it better since most of my timing chain engines got slightly quieter on it.
But between 20+ cars the price on Mobil 1 adds up quick, so I found different oil that offers me same benefits, but is easier on the wallet.
Currently I'm a huge fan of Full Synthetic 15W40. Especially in timing chain engines (unless one has to deal with harsh winters obviously). My Southeastern US climate definitely allows for it, and it meets all API certifications needed. Availability anywhere in US is also nice. I use it in all cars, with exception of Scion xB (it's currently on Valvoline Restore and Protect 5W30 diet) and Kia K4 (free dealer oil to maintain lifetime engine warranty).
On one hand - yes.There's an argument to be made that HDEOs are not good for gasoline engines.
Surely that Tacoma is longer than 15 feet!Here’s a 15’ Tacoma with the 1GR-FE and 5 speed auto with 900k miles! The OP (TacomaNation on FB) is a Pilot Driver for semi trucks. Original engine and transmission. Per OP it’s had OCI’s of 5k with Mobil 1 5W30 full synthetic. Last time they posted it had close to 950k miles. Truck is really clean considering the miles. View attachment 296411
‘15 as in 2015. You knew what I meant!Surely that Tacoma is longer than 15 feet!
15' = 15 foot15’ as in 2015. You knew what I meant!![]()
