Originally Posted By: BigCahuna
Ok the deed is done. The filter was a bit of a pain due to my std size 1 1/4 socket, But with the help of channel lock plyers it's done. I used the called for "ac delco filter" because Napa would have to have it picked up at their warehouse, and I just wanted to get it over with. I did hit the 1 st day of their month long syn oil sale tho, $3.99 a qt. Now while reading the manual and resetting the OLM, it said it counts the revolutions of the motor to determine how much life is left in the oil. And it says 3000 mile changes. It went 5500 miles on what ever oil the dealer put in it, before the olm said to change it. I was planning on going 7 or 8 months or 6500 miles before the next change, due to the oil I used. Is the filter anything to be concerned with going longer then what GM says?.,,,
The OEM filter (or pretty much any name brand filter) can last the OLM recommended change, as well as the NAPA Syn. Just change it when the OLM says to and you are fine.
