New tires = worse MPG?
Columbia, SC
Vehicle: 2017 Miata, 6spd, 87,000miles.
Scenario: My daily commute is 35 miles, one way, 90% freeway. Mostly 60-65 mph. I recently (~6 mo) replaced the tires on it, with the same Michelin PS4 All Seasons that it had before. The previous ones had about 38,000 miles on them. The onboard MPG computer, with the old tires, showed an average of 37-38mpg. Since I installed the new tires (nothing else has changed), it's dropped to 33.5mpg. I never bothered to do the actual math, purely went off of the computer. Regardless of its accuracy, that seems like a significant drop. What would cause this, higher rolling resistance?
That's my general observation as well - changing to new tires equals worse mpg. I think it's to do with greater rolling resistance due to 'softer' tire with more tread. If distance travelled is calculated based on tire revolutions then that will play its role as well.
A few previous threads which may be of help:
I believe 90% of the lost MPG result from the cause in post #2. Replace with the same brand and model of tire, and I bet you get the same results as the first set. Bad at first, slowly getting better as the tire wears. This has been my experience with tires an MPG.
Per CapriRacer in that 4th link, "All other things being equal, new tires will consume more fuel than worn out tires. This is due to the additional mass in the tread area for new tires." I don't want to be taking the quote out of context, so be sure to read that thread too.
I understand tires can cause slight deviations in fuel economy, but I'm skeptical it's the reason for 3-4mpg difference as you're reporting. I'm open to being educated on the subject if I'm mistaken here.
Yup. There are essentially zero controls on the myriad of variables in everyday driving. All of which (or a combination of several) can be significant.
MIL replaced her tires with an economy tire and took a consistent 3 mpg hit with her Camry. They were Tiger Paws.
I’m a bit skeptical about that too. I just got new tires for my Civic the end of November and my fuel economy is still the same as it was last year in the cold weather (in the cold weather it averages 44-45 and in the warm weather 49-50)
