I run the XDS at weak (e-diff) which uses the inside brakes to help you turn through corners/work on the understeer.
While that makes plenty of sense with stock 312 mm rotors, not necessary perhaps with the BBK.
It's probably a good idea testing how good the BBK handles track duty, and then if it doesn't get
too hot try the factory XDS setting again.
The rest of my braking settings I leave alone.
Leaving the Emergency Brake/Hydraulic Brake Assist setting alone is a mistake. It makes a huge
difference with just costing you five minutes of your time if you have VCDS. I'd say it's a must do.
That said, I'd also reconsider upgrading to vented 310 mm rear rotors. I'm going to do a similar
mod to our little Cooper even though it won't ever see any track use. Stock is 280 mm front and
259 mm rear, same as any R55/R56 One, Cooper and even Cooper SD. It's quite easy to upgrade
to Cooper S (not SD) 294 mm fronts and JCW 280 mm rears as the calipers remain the same and
I just need the corresponding carriers, rotors and pads. I'm aware you'd need new calipers but it
will be worth the effort I bet as it will very most probably work much more in harmony with the
BBK on front.
