New Shell Gas Formula - Enriched with Nitrogen!
Originally Posted By: MarkC
As I was filling up at the Shell station on the corner and reading the sign about this, I also noticed a new sticker on the pump saying the gas contained 10% ethanol, which means it will be the last time I buy gas from there.
Boy you wouldn't like this then:
http://reviews.cnet.com/8301-13746_7-10194194-48.html
If the Ethanol blenders have their way we will be seeing E15 in place of E10..
Currently my local Shell gas station wants $2.70/gallon of regular. I'd rather use another brand that's much lower in price than my local Shell. Corporate greed is alive and well in Los Angeles!!!! That fancy gas is outta my pocket book to consider trying it in my cars. It's better to add a bottle of Techron as it's easier on the wallet.
Durango
Wow. I saw Shell at $1.63 here. Only cheaper place was Murphy in the Wal-Mart.
I don't use Shell because of the ethanol content. There's (as far as I can tell) an independent station with ethanol-free gas I go to instead. The increased fuel mileage more than makes up for the extra $1/tank cost over Shell.
Durango
Wowser, my local Shell station which is the biggest rip off station in this small Northern California town is $2.25.
Bought a full tank Sunday morning(17 gallons). It's probably just the placebo effect, but the truck is running FINE. Here in MO all gas has 10% ethanol, so the mileage is the same. I paid $1.64 a gallon. So I will use it when its handy. Today I ran the A/C as the truck was hot after sitting in the sun all day. It seem to handle the low end takeoff with the manual trans better than I recall from last summer.
The gas
Originally Posted By: Lyondellic
I still find Shell's claim to be misleading. I use Shell gasoline exclusively, so I am not trying to slam the quality of their fuel. Nitrogen may be one component of a new cleaning system that they have developed, but I doubt that it has any cleaning ability all by itself. Think about it:
Nitrogen (N2) is a colorless, odorless and tasteless gas that makes up 78.09% (by volume) of the air we breathe. It is nonflammable and it will not support combustion. It is colorless, odorless and tasteless.
Nitrogen gas is slightly lighter than air and slightly soluble in water. It is commonly thought of and used as an inert gas; but it is not truly inert. It forms nitric oxide and nitrogen dioxide with oxygen, ammonia with hydrogen, and nitrogen sulfide with sulfur. Nitrogen compounds are formed naturally through biological activity. Compounds are also formed at high temperature or at moderate temperature with the aid of catalysts. At high temperatures, nitrogen will combine with active metals, such as lithium, magnesium and titanium to form nitrides. Nitrogen is necessary for various biological processes, and is used as a fertilizer, usually in the form of ammonia or ammonia-based compounds. Compounds formed with halogens and certain organic compounds can be explosive.
Maybe they have found that nitrogen offsets some of the detrimental effects of ethanol.
i noticed the same thing w/ my light flywheel it's sensitive at low rpm takeoff. it seems like good stuff. i went to the Shell website and saw something that made me lol
from the first response line of the FAQ
"Shell V-Power is the best, most advanced product ever."
http://www.shell.us/home/content/usa/pro...out_vpower.html
I'm glad in this part of MI no blended ethanol [censored] until you hit the lower west part. Shell gas here is on average the same as all other brands. I fill up at Shell because of convience, and have never had an issue with their gas. my roadmaster loves Vpower and will continue to use it :)
Because I want to stir the pot. Both of my cars on this beyond getting 8-10% better mpg and rear end analysis that says performance is better. Now add to that 21 days of higher idle. About 300 to 500rpm.
Durango
In my small town, our Shell just got the signs put up withing the past couple of days and it about the same price IIRC. If I were to use it, I wouldn't be expecting anything dramatic.
how can they do that?? cars can only use up to a 10% blend of ethanol.
ah freaky deeky, pls explain
Originally Posted By: From somewhere on the Internet
Nitrogen is added as a compound of another chemical such as a polyetheramine that contains nitrogen bonded to something else such as ammonia.
When the chemicals are exposed to the extreme heat in the combustion chamber the detergent breaks down and releases the nitrogen and oxygen combined in the polyetheramine and the nitrogen combines with another nitrogen atom and creates a huge amount of heat.this heat plus the free o2 cleans up all the carbon deposits in the combustion chamber.
Explosives work the same way for your reference.The more freed nitrogen the bigger the boom.
WOW!! sounds like you know what the [censored] your talking about!!
I would love to take credit for knowing that before I posted it, however it was Google,and paying attention to guys like Mola, that brought me to that knowledge.
I know it seems weird but I have been running this fuel in the past 2 tanks in the GF's Corolla and the ping seems to be reduced quite a bit.
It could be a coincidence, but if it isn't that would be great because I have not been able to do squat to reduce the ping issue on this car.
I also use the Premium version in my MarkVIII, haven't noticed a difference, running smooth as always.
I filled up again yesterday and I have noticed that my engine is running a bit smoother than usual when idling. No fuel economy difference noticed yet.
I also noticed on the pump that it says V-Power '91 Octane contains no Ethanol, Silver contains up to 5% and Bronze contains up to 10%.
Didn't know that you could still buy fuel without E. in it... This makes me happy!!!!!
