Living in WV I find it a great place to break in an engine. Some flat, just vary RPM, some mountain pulls just keep it under 3,500 rpm and then some engine braking going down the other side of the mountain to work in the back side of everything. Knock on wood doing this breaking in I’ve never had an oil burner. I have mostly owned VW and Jeeps and all have gone over 150k with no problems.I agree with this. I like building cylinder pressure to seat the rings without revving the engine hard during break-in. Just my way, as there are many other ways. The WV mountains are awesome to drive through, by the way!
Probably a fluke.I would just drive the thing and not even give its a moment's thought.
I used to believe strongly in an early oil change or two on a new car as well as a careful break-in procedure.
The last few we've bought we've just used like cars and I've changed the oil at the recommended OCI.
Guess what? Nothing bad happened with any of them.
Drive this Toy. It isn't picky about break-in, use or OCI.
I will stop at every rest area to do it. Probably stop at a weigh station too, ask the DOT officer if he can help me hold the flashlight while I get the filter offNo way dude, 12x on the trip or RIP.
Aside from just leaving it in gear(it's an automatic anyway) how do you engine brake a gasoline engine? No handy switches on the dash to turn it on and set level 1,2,3Living in WV I find it a great place to break in an engine. Some flat, just vary RPM, some mountain pulls just keep it under 3,500 rpm and then some engine braking going down the other side of the mountain to work in the back side of everything. Knock on wood doing this breaking in I’ve never had an oil burner. I have mostly owned VW and Jeeps and all have gone over 150k with no problems.
Mine is "in transit" so it sounds like it's arriving from Toyota. Unless it's coming from another dealer and got some test drives there it should be very low mileage. I'm hoping single digits just for the photo OP to send to my wife(and then another once I arrive)We bought our 2014 Tacoma brand new and it had 22 miles on it from various test drives. I drove it until about 500 miles then changed the oil. Our brand new 2022 Rav4 Hybrid XLE had 2 miles on it and I changed the oil at 500 miles as well. Just drive it and change it when you get back home.
It’s heading over the Ambassador Bridge as I post.Mine is "in transit" so it sounds like it's arriving from Toyota. Unless it's coming from another dealer and got some test drives there it should be very low mileage. I'm hoping single digits just for the photo OP to send to my wife(and then another once I arrive)
Hell, I have my NEXUS, I could just go pick it up at the plantIt’s heading over the Ambassador Bridge as I post.
I believe the RAV4s are assembled in the Cambridge, Ontario plant.
https://tmmc.ca
Having my CDL I tend to pre trip my POV as well. I'll probably even do one before I sign the paperworkCheck the tire pressures. Including the spare if it has one. Most spares ( full diameter, but narrow) require 60 psi. Most have less than 20 psi. Usually 10 to 15 psi. Sometimes even new vehicles. Brand does not matter.
Tire shops are just as bad. Almost never all 4 are set to the same, and proper psi.
I would recommend using a " better" oil filter than the Toyota brand oil filter. And any good quality, reputable brand of oil at the specified weight for the engine.I'm getting a RAV4 LE at the beginning of August and will immediately have to drive it from NC to ND. I'll have one day in NC after taking delivery that I'll be visiting family and plan to tool around neighborhoods and a few highways for probably 3-4 hours to try and hit 100 miles with speeds between 25-55. Next day, on leaving, I'll probably take state highways and some US highways.
Knoxville TN will be right around 500 miles and I plan on getting an oil change. I've already ordered Toyota 0W-16 and filters in case dealers or lube centers are out of stock.
Given I'll have to cross some mountains at some point, I'm wondering if a 1000 mile or 1500 mile change would be warranted, or should I just push into ND and change it on arrival?
I'm avoiding West Virginia and taking I40 to avoid the steeper mountains on I77 and US35.
Any tips? Changes you'd recommend? Different oil? 0W20 instead? Drive it in reverse?
Put it into “S” which is all the way down and to the left on the shifter. Then select an appropriate gear, it will now NOT let the transmission up shift beyond that point, so you can also force it to downshift as well to control how much engine braking you want/need.Aside from just leaving it in gear(it's an automatic anyway) how do you engine brake a gasoline engine? No handy switches on the dash to turn it on and set level 1,2,3![]()
I added one when I fueled it with non-ethanol first fill. Changed oil at 200 miles, Pennzoil Platinum 0W16. Added techron again on the fill before the change I got at 1700 miles. Again, PP 0W16. I'm at 2500 miles now and doing short to and from work runs. I get off work ne7kxt Tuesday and need to turn in the Volvo rental.While you're driving add a bottle of tectron fuel cleaner.
Why was use E0 fuel important to you?I added one when I fueled it with non-ethanol first fill.
The engine makes the most metal during the first hours of operation.True but you can just pull the drain plug at 5k and keep the same filter since 5k isn't much and then have the dealer change it by the 10k mark and the dealer would never know that you did that and used a 20 or 30 grade.
Other than Black Mountain Pass, and 40 thpugh Asheville. The only way out of NC with no mountains is 85s.I'm avoiding West Virginia and taking I40 to avoid the steeper mountains on I77
