New or Used Air Compressor?
Taxachusetts, USA
I am going to start doing my own fluid filming on my 4 vehicles. Ideally, I would see about 4 CFM at 90 PSI. This puts me in the realm of a large portable air compressor, or a stationary. I like the idea of a compressor that has serviceable oil, but so many are oil-free.
Anywho, Ive been looking at new and used models, and see some appealing used compressors near me for about 1/3 to 1/4 of a new unit. Any thoughts on this?
Are you sure its 4cfm or "average 4 cfm"
IIRC if you are using the FF spray gun you want 6-8cfm at 80psi+
for continuous spraying
That puts you into 230v territory.
I bought a Grip Rite GR2500 at a local auctioneer for $25, tax included. It’s beat up, but builds air and performs without issues. I would like a larger tank, but for how often I undercoat vehicles (2x a year total) it works no problem. I would prioritize a compressor that is oiled. They last much longer and maintenance is dead simple.
Oilless compressors are typically for 33% duty cycle, meaning not continuous use. Some are, like VIAIR, but most commercially available units that are oil-less, will not last under continuous use.
I suggest an oil lubricated unit for what you are going to be doing, with a large tank,
Speaking from experience I would get at least a 60 gallon compressor. Bigger the pump the better. Ive been spraying fluid film and now woolwax since 2012. Started out with a 60 gallon compressor with a 12 cfm pump. It was sufficient but I had to add and air dryer to keep from spraying moisture out with the spray gun. Anything smaller is going to run a lot and you will fight with moisture in the air and in your sprayer.
For homeowner use once or twice a year, why would anyone need 60 gallons? Sure, bigger is better for continuous spraying, but that’s unnecessary imo.
4x a year technically.
also 60gal doesn't take up any more space vs a 20 or 30 unless you are stowing the portable unit under something.
its stationary however.
once you have big air you can find more uses for it.
Around here, used compressors are either clapped out borderline scrap metal, or people are asking five bucks less than new.
If you're not in a hurry, get a good idea for specs, keep your eyes open and see if a used deal comes around. Otherwise, used makes no sense, in this area.
Buying used poses a risk if they did not properly maintain it and drain it, if it rusted internally and explodes it will go off like a bomb destroying much near it.
Buy new, maintain it and keep it for decades instead of buying a risk.
