SO the ol' high mileage Camry has this strange problem where the oil pump buzzes when the oil is cold. It sounds pretty bad. I can really feel harsh pulsation if I hold the filter can too, so maybe the geroter cracked, maybe hydraulically from revving it in the cold with really thick oil in, hard to say till i get it out. Anyway, timing belt, tensioners, idler pulley (mayyyybe water pump) and every seal in the front needs to get changed; and obviously the oil pump. So all parts orderd and arrived and I'm checking out the oil pump. Now. being machinery lubrication freak that I am, had the pump dismantled within minutes! Just checkin out the geroter and pressure relief valve... went ahead and prelubed the pump gears and housing with a concentrated MoDTC additive (which is in something like a SAE60-80 base) so that moly is the first thing the bare metal sees. But that's not enough... I had to shim the relief 1.5mm also.... in anticipation of using the thinnest, highest VI oils I can find (looks at the Idemitsu 0w20). Which leads me to my next questions: Am I suffering from BITOG induced neurosis? and .... is there anthing else that I can do to this pump to 'make it better'? lol porting the inlet/outlets??
