Originally Posted By: morris
to:ZeeOSix answer: if a filter will only pass 10 gpm, and the engine pump will only pump 5 gpm,at 2,000 rpm. then at 4,000 rpm it "might" pump 15 gpm, over running the filter.
The pump might put out 15 gpm through the filter/engine, but only if the pump is putting out 15 gpm before it goes into pressure relief. Not many engines in stock street cars can pump more through a filter than the filter can flow. Most higher tier oil filters can flow 10~12 GPM of hot oil before the filter will go into bypass.
PureOne filter, 5 PSID at 12 GPM (5w-30, 200 deg F oil).
in the early 60s chrysler found that the 413,426 race engines, oil pump couldnt keep up at 6,000 rpm. they found the suction passage in the block and the pipe to be to small. so they made a larger passage on some engines, and a duel external suction piping on others. dont forget ANY pump will push better than it sucks
The oil pump can only put out what it can take in.
