We actually looked at a red one too, red is not normally my color, but Mazda does it right.Second only to the Mazda red
Where are you purchasing the OEM filters?
I may be a bit biased, but I agree 100%We actually looked at a red one too, red is not normally my color, but Mazda does it right.
Are you going to run Valvoline Extended Protection next? I'm thinking about trying it as well.At the dealer. $8.xx each.
So a question how is the cylinder deactivation working out for you? I looked at a 2017 today a Sport. Because I'm very Leary of the cylinder deactivation. I was very impress with the 2017.Just picked up a '22 CX-5 for my wife with the 2.5L NA Skactiv-G mill. Factory specs Mazda 0W-20 full synthetic and changing up to 10,000 miles under normal conditions.
Do these need an early change after break in?
Any recommendations on oil? I am thinking about running Mazda or Idemitsu full synthetic and changing every 7,500.
Thanks!
PimTac where are you getting your filters from the Dealership an Autoparts store or online.I have run Idemitsu x2, Valvoline Advanced Synthetic, Havoline Pro DS, and Mobil 1AP, all in 0w20. On deck is Valvoline Extended Protection.
These SkyActiv motors are easy on oil. I change mine every 5000 miles/one year.
Use the OEM Roki filters. They are excellent and competitively priced.
Just shy of 4 months ago (20 Oct.) we traded in our purchased new '16 Mazda3 Sport (base) w/21K.
We both use it and are EXTATIC that this car isn't being used to commute-a COVID silver lining.
The Mazda3 was a joy to drive. This CX-5 is so much more. Good luck with yours.
Ours has a 2.5NA. Is that the "G mill" mentioned above?
I see one bloke here recommends NOT using an"xxw20" except for cold climes. Are any of the "good" 0W-30's OK?
We went with the dark blue as many here do. A Mazda dealer on US 46 (Lodi, NJ) has fronted the lot with red ones....looks cool.
IIRC MB229.71 and vw 508/509 are mostly for engines with exhaust particulate filters..
Mobil 1 ESP X2 0W-20 has both MB229.71 and vw508/509 and "meets or exceeds" api SP
Keep in mind the Lubrizol chart isn't designed to compare specs outside of a given body or manufacturer, so you can't directly compare SP to the MB or VW certs, it is just designed to show what emphasis the approval places on each of the areas, relative to others within that same family.View attachment 89015
Mobil 1 ESP X2 0W-20 would be preferable, however, for the price, I would choose Castrol EDGE Extended Performance 0w-20.
Then again, the OP can run 5w30 as well, and there are many great choices.
Valvoline XL-III 5w30 is API SP and MB229.52 approved. The owner manual allows for 5w30, so the warranty wouldn't be a concern with this one. An HTHS of 3.5 is preferable.
Valvoline Extended Protection 5w30 has an HTHS of 3.2 and is a great choice as well.
Don't get me wrong, I like M1 products as my signature shows, however, I believe there are many other great choices out there.
That’s like Mobil 1 Annual Protection is back ! However, if going under 10k - gotta wonder if the PAO/GTL mix doesn’t have a lower NoackKeep in mind the Lubrizol chart isn't designed to compare specs outside of a given body or manufacturer, so you can't directly compare SP to the MB or VW certs, it is just designed to show what emphasis the approval places on each of the areas, relative to others within that same family.
In terms of base oil selection, Mobil is clearly willing to spend more on the EP product:
ESP
EP
Shoot, thanks for reminding me. It's easy to forget sometimes as it's tempting to make comparisons.Keep in mind the Lubrizol chart isn't designed to compare specs outside of a given body or manufacturer, so you can't directly compare SP to the MB or VW certs, it is just designed to show what emphasis the approval places on each of the areas, relative to others within that same family.
So you think it costs them more money to blend Mobil 1 Extended Performance 0w20 than it does ESP 0W-20? Yet they charge more for the ESP product, and given the approvals, it "seems" better. I know that MB229.71 was designed with light-duty diesel engines in mind, with particulate filters. So I wonder if Mobil 1 Extended Performance 0w20 could be used in place of ESP 0W-20 for gasoline engines if it's indeed a superior product. What do you think?In terms of base oil selection, Mobil is clearly willing to spend more on the EP product:
Would depend on what grade of PAO they are using there I suspect.That’s like Mobil 1 Annual Protection is back ! However, if going under 10k - gotta wonder if the PAO/GTL mix doesn’t have a lower Noack
But, EP is certainly easy to find …
