I haven't seen any owners manuals that say "or later, EXCEPT SM"!
Quote:
It says what where? The Amsoil website gives the specs on their new small engine oil, and SM is not included. We all know that lawn mowers do not YET have catalytic converters, which the SM specs are specifically meant to protect.
Quote:
SM is a PCMO, and, while not the optimal oil for small air cooled engines, will probably give most folks reasonable engine life. But, why use it when better oils are available? Many use a 15W40 HDEO, with excellent results.
Quote:
So, is it better to use SJ rated oil like what is recommended in the Honda engine manual...
Quote:
I can't get exactly 86 octane gasoline. I can get 85 octane or 87 octane. Which is better to use?
Quote:
I like the way the Honda engine is designed. The air filter is in a quality unit and the air filter looks pretty good, although it is expensive.
Quote:
I am also going to check around a little and see if Honda might make motor oil for their own lawn engines. If so I will use the Honda oil.
Quote:
The engine already has about an hour of operation and I figure I will mow the grass 1 more time and check the oil and if it looks like it is getting dirty or has shiny particles in it I will change the oil.
Quote:
I figure I will change the oil once a month. After all, it only takes 20 ounces of oil and a couple of quarts of oil will last 3 oil changes.
Quote:
I may need to get a spark plug socket for the spark plug. But I will probably not need another spark plug until next year. About the only other thing is getting the blade sharpened occasionally.
Quote:
Saw bottles of Honda small engine oil, 10W-30, at our local Tractor Supply Center (TSC, www.mytscstore.com) that had an API SM rating.
Quote:
I tried to find diesel oil in 10W30 viscosity but I could not find it.
Quote:
As far as I know these small lawnmower engines all take 20 ounces of oil.
