New Flex-Gate at our HOA
The 'roundness' of the bend intrigued me.
I'm thinking strong youngsters took the gate off and bent it, using a telephone pole as a mandrel, then rehung it,
Then I saw the scratches on the swing end.
Puzzling. You'd expect such a gate to kink sharply.
Shimmed with tie straps. If you mounted your mailbox like that you'd get a violation letter from the HOA. :ROFLMAO:
The mirror is an on going experiment to see if it helped and would people use it. I initially installed it with a blue ratchet strap. The SS clamps were supposed to be an upgrade. The problem is the clamps are round and the gate post is square. So you need something extra for the clamp to press against so it's tight.
Also the mirror is not high enough so the mirror will need to be mounted on a piece of metal that will allow it's to be mounted a few inches higher and still not sure about this particular mirror as vibration from opening and closing of the gate causes the mirror to shift position a little and then need to be re-aimed.
Thus the experiment is continuing.
