Quote:
Ford is jumping the gun on the final fuel economy ratings for the 2011 F-150, projecting it will have a best-in-class rating for its 3.7-liter V6 ( 23 mpg highway), and its 5.0-liter V8 (21 mpg highway). Although the ratings have not yet received EPA certification, most automakers' projections fall in line with the final ratings. Both ratings are for the 4X2 models. The 23 mpg expected from the 3.7-liter engine is a 9.5 percent improvement in fuel economy over the most fuel-efficient F-150 to date, the 2009 F-150 SFE (Superior Fuel Economy).
The 2011 F-150 achieves the higher mpg ratings through a more efficient six-speed transmission and an electric power-assisted steering system. Ford says that it is the only manufacturer to equip its entire full-size pickup lineup with six-speed gearboxes as standard equipment. No word yet on what numbers we can expect from the 3.5-liter EcoBoost V6, but the 6.2-liter V8 is projected to get 12 mpg in the city and 17 mpg on the highway. F-150 models with the 3.7-liter V6, 5.0-liter V8 and 6.2-liter V8 are scheduled to hit showrooms later this year. The EcoBoost will be available in early 2011. More engine details from the press release after the jump.
3.7-liter four-valve Ti-VCT V6
The 3.7-liter will be the most powerful, capable and fuel-efficient base V6 of any truck in its class. Key attributes include:
Projected best-in-class 23 mpg highway (4x2 configuration), pending final EPA certification. Also delivers 16 mpg city
Best-in-class 302 horsepower at 6,500 rpm
Unsurpassed 278 lb.-ft. of torque at 4,000 rpm
Best-in-class 6,100 pounds maximum trailer tow
Ti-VCT (twin independent variable camshaft timing) creates precise, variable timing control of both the intake and exhaust camshafts to optimize power, performance and fuel economy
E85 flex fuel capability
Piston-cooling jets, which squirt oil on the underside of the pistons to keep the piston crowns cool under extreme operating conditions
Forged-steel crankshaft for improved durability
Built at Cleveland Engine Plant
5.0-liter four-valve DOHC Ti-VCT V8
The 5.0-liter V8 in the 2011 F-150 offers many class bests compared with comparable base V8s, including:
Projected best-in-class 21 mpg highway (4x2 configuration), pending final EPA certification
Best-in-class 360 horsepower at 5,500 rpm
Best-in-class 380 lb.-ft. of torque at 4,250 rpm
Best-in-class 10,000 pounds maximum trailer tow
New strengthened block and new cylinder head optimized for performance and enhanced cooling
Unique intake camshafts, combined with Ti-VCT, composite intake manifold and optimized compression ratio for improved low-speed torque and towing capability
Forged-steel crank and all-new oil cooler enhance durability
Built at Essex Engine Plant; Windsor, Ontario
6.2-liter two-valve SOHC V8
The 6.2-liter V8 is a premium engine offering on the 2011 F-150. It is now standard on F-150 SVT Raptor, with expanded offering on other specialty applications. Its attributes include:
Best-in-class 411 horsepower at 5,500 rpm and 434 lb.-ft. of torque at 4,500 rpm vs. all competitors
Best-in-class 11,300 pounds maximum trailer tow vs. all competitors
Projected 12 mpg city, 17 mpg highway (4x2 configuration), pending final EPA certification
Durability of race-proven components and technology showcased in November 2008 when a 6.2-liter Raptor R not only survived the grueling Baja 1000, it earned a podium finish. The same engine then completed every mile of the 2009 Best in the Desert series
Utilizes a large bore and shorter stroke. This approach to creating power has its roots in storied Ford racing engines. The large bore allows for larger intake and exhaust valves for improved engine airflow, and the short stroke allows higher engine speed for increased horsepower
Because of the large bore size, two spark plugs per cylinder are used to more efficiently burn the fuel-air mixture in the combustion chamber, enabling better fuel economy and increased engine torque. The twin plugs also help maintain a smooth, stable idle
Built at Romeo (Mich.) Engine Plant
3.5-liter Ti-VCT EcoBoost
A premium powertrain offering available after launch, the 3.5-liter EcoBoost has more torque than any competitors' V8 with the fuel economy of a smaller-displacement engine. This EcoBoost engine will establish a new benchmark for its combination of performance capability and fuel efficiency. Its attributes include:
365 horsepower at 5,000 rpm on regular fuel
Best-in-class 420 lb.-ft. of torque at 2,500 rpm on regular fuel
Best-in-class 3,060 pounds payload vs. all competitors
Up to 90 percent of peak torque available from 1,700 rpm to 5,000 rpm
New benchmark for combination of performance capability and fuel efficiency
Ti-VCT creates precise, variable timing control of both the intake and exhaust camshafts to optimize power, performance and fuel economy
Intake and exhaust camshafts optimized for improved fuel economy and performance
Cast exhaust manifolds for heavy-duty operation and durability
Improved manifold and cylinder heads for improved performance
Direct-acting mechanical bucket (DAMB) valvetrain with polished buckets to reduce friction and improve fuel economy
http://blogs.edmunds.com/strategies/2010...-for-f-150.html
And that's your Ford news for today!
Sincerely,
Mr. Critic, the person who starts controversial debates.
![lol.gif](https://bobistheoilguy.com/forums/graemlins/lol.gif)
Sincerely,
![wink.gif](https://bobistheoilguy.com/forums/graemlins/wink.gif)
