I recently purchased an '04 Chevy with the Duramax diesel in it. I want to treat it right, which is why I'm asking questions here. Forgive me if this is a little long, but I'm anxious to learn!
1. A local dealer swears up and down that these engines come from the factory with Mobil 1 Delvac 5-40 full synthetic oil. While it looks like an excellent oil for this application, I think they're totally full of BS! What do these engines really come from the factory with?
2. I plan to run petroleum (dino) oil during the break-in process, as suggested by most of the members here. I have a case of Delo 400 15-40 laying around that I'd like to use. It meets the CH-4 specified in my owner's manual. With it, I'm planning to use the factory spec AC Delco oil filter. Would this be a good combo for the first 10,000 miles?
3. After the first 10,000 miles (if that's long enough) I'm planning to switch to a full synthetic and a bypass filtration system. I'd like to use Amsoil, but they don't offer a 5-40 designed for this type of engine. My manual specifically warns against using anything other than 5-40 (in colder climates) or 15-40. This leads me to the AME 15-40, but I live in Montana and see lots of cold weather at any time of the year. For example, it's not uncommon for me to make a 30 degree start-up in July! For this reason, I'd like to use just one oil grade year round if it will offer good protection for the engine.
As you can see, I'm lost in the maze of diesel oils! Please lend me some advice. Thanks.
