Well here's my first post in these forums.
Let me begin by saying I worked for Champion Labs from 1982 until 2000. I continue to work in the filtration field, in Hydraulics and Pnuematics.
But a friend of mine sent me a link to this site and this thread. He's a "fleet" owner with 5 cars. He never sells anything..lol. But in days gone by we used to work on cars together. We live in different States now.
My job at Champ ran the gammit from sales to marketing to training. I also represented Champion as a technical committe representative on the Filter Manufacturers Council for about 3 years , which includes all those Companies that build Filters in the USA. Here's their website:
http://www.filtercouncil.org/
So I think I know a little about filters.
Let me clarify a few issues that i've read on this thread.
First: For those who don't know who Champion Laboratories are...they are the #1 private labeller of automotive and heavy duty filters in North America and #2 worldwide. They build about 500,000 filters a day. They have the engine plant business for Ford ( which is a different filter than Motocraft), engine plant business for VW/Audi in the US and Mexico, and some others. Not to mention 100's of private label accounts from Harley to Caterpillar. Also some of the Oil companies filters like Valvoline, Shell, Mobil 1, etc.
Second; Yes this is a new design, Ecore. However, some of you are speculating that all filter companies will build similar designs. Maybe even metal center tube and end cap filters will become a thing of the past.
If you stop and think of what a filter company has to do to build a certain design, you may come to realize, metal center tubes and end caps are going to be with us a long, long time.
Champion invested in a special production line in order to run the Ecore design. The rest of their plant facilities are dedicated to the standard design that we all have come to know and love.
The same would be true if a different manufacturer would want to build a similar design. It will take heavy investment on their part. Will they do it? I can't answer for sure but if the market is going that way, then they will. But it will take some time before they are up and running if they do.
As for cartridge elements, yes they are going the way of being environmentally friendly and you will see more and more automotive manufacturers incorporate this into their engine design. That is what will drive the market. Not a retrofit on existing vehicles.
Can you imagine being told you can't use a spin-on fitler any more and you must convert over to a cartridge.? I don't see it happening.
Third: I had a laugh at the posts about "plastics and Nylon". In the hydraulic industry these type filtration products have been used for years to great success. In high..very high..temperature applications and under very high pressures ( as much as 6,000psi). It all depends on what the specifications are what a manufacturer needs to use.
One thing I know about Champion is they darn sure aren't going to use any product in their filter element construction which won't exceed what the worst case scenario is that the element construction may encounter. The obvious answer is due to warranty considerations. It's not worth it to build a X dollar filter sold at retail and have to pay thousands in engine warranty claims. You don't make profits that way.
Fourth: One of Champions strengths as a manufacturer is their ability to make the component parts of the filter in house. So they stamp out their own cans, back plate assemblies, make their own relief valves, end caps, center tubes, and most critically blend their own glues ( or plastisol is the correct term ). I'm reasonably confident they do the same for the Ecore element.
Fifth: The Ecore design is limited to certain part numbers and you will see it under various names due to the private labelling Champ does.
But it won't be for every part number they build unless they convert every production line.
Btw..I use the SuperTec filter on my personal car, wich is why I was pointed to this thread. Why do I use SuperTec, you might ask. It is the best filter for efficiency at removing contaminant out of oil for the price and out performs even the expensive Fram element. I used to use the AC Duraguard Gold element, also built by Champ, until the idiots at AC decided they didn't want to mess with a high end, high price element. That was a Great filter. If you want a better filter than SuperTec, then use the Mobil 1 element.
Oh, and I use Mobil 1 oil. After all my training sessions where I had to listen to the oil men pitch their product and I did the filter bit, that's what I figured was best. I use oil analysis every oil change and change my oil at about 15,000 miles. I could push it to 20,000 or more if I really wanted but that's my safety factor.
