I recently fell on my old Suunto DP 65 Global and the matchbox case cracked. I bought a new one but didn't care for the cheaply made needle bearing without the sapphire the old version had. I swapped the capsule of my old compass into the new housing. Like new but better than the new version.
The intended use should dictate the type of compass you buy. For outdoor and general use I’d suggest an orienteering/baseplate compass. The Suunto MC-2 that Pablo mentioned, or a Silva Ranger doitmyself pointed out, would be a very good and popular choice. This type of compass is ideal for learning how to use a compass with a map. Mirrored, lensatic, prismatic, and transit compasses are more specialized and allow you to measure bearings, angles, inclination, etc very precisely at the cost of being less user-friendly, more limited in use, more fragile, and more expensive. A global needle is always a good feature because the needle won’t get stuck as easily if you don’t keep your compass level.
A few more things to consider: Get a compass with a 360° scale, not one in Mils (6,283 divisions) or in quadrants unless you need either of those options for specialized use. If you see a good deal online, make sure the compass has the right type of scale because many models come in different versions. Also, make sure the model you buy has an inbuilt declination adjustment. And unless you expect only stationary use, go with a compass with a liquid-dampened capsule. Undampened compasses suck while on the move.
Here is an example of a compass I would not recommend for general use. This is my modified M-2 pocket transit that is not only used for azimuth but especially for slope, strike, dip - angle measurements, with a precision of +/-0.5°. This Brunton can be used for navigation but it's best used on a tripod. or a tree stump etc because the needle is not fluid-dampened and may take 12 seconds to stabilize. Don't use this kind of compass for orienteering - it will drive you nuts despite its potential for precision and accuracy.
For orienteering on the fly you might be best off using a wrist compass. It's not very precise and doesn't have a declination adjustment so you may have to do a little math but it's super-rugged, can be used while running, and is legible in the dark. You can even go open water swimming in the dark if you are into crazy stuff like that. It does have an aiming feature through the capsule and a vertical readout so you can take a decently accurate bearing.
