Labman, isn't it often tough to polish out the corrosion in the caliper cylinder?
Also, does not the corrosion happen where the fluid is? I mean doesn't old fluid contribute to corrosion? I am interested in your opinion due to the many rebuilds you have done.
I always thought frequent fluid changes helped prevent internal corrosion of the brake system componenents. Also, I always found it hard to believe that the dark brown fluid that comes out has similar properties as the original fluid. I would love to see a used oil analysis on that brown gunky fluid.
