NEW AMSOIL PDS IS OUT
Despite Amsoil's claims about Dexos 1 Gen 2 achievements, is it safe to assume these will never be on GM's official list of D1/G2 licensed products?
I would seriously doubt it. If they won't spring for API certification, don't see why they would pay GM for Dexos licensing.
No doubt the SS line probably won't be but the XL and OE are API certified whether they pay for the DEXOS licensing on the other two... I suspect they would but who knows time will tell. I don't see those PDS listed yet.
Will the XL and OE lines claim that it meets Gen 2 qualifications? According to their PDS, they specifically say that their Signature Series provides LSPI protection.
PDS isn't out that I could see for OE an XL but they are also reformulated as well to combat LSPI. Whether or not they pay for the licensing that is to be determined or call them and ask.
At least in the SS line, Amsoil comes right out and says their sulphated ash levels are too high for dexos1 Gen 2.
Here is a read on the XL. Nothing specific indicating they have paid for the licensing, but "they" do indicate it passed the testing.
https://www.amsoil.com/newsstand/motor-oil/articles/xl-synthetic-motor-oil-stronger-for-lon/
It's been discussed before. SS and XL lines will NEVER meet Dexos specifications because of the SA levels that Amsoil uses in the add packs. They both exceed 1.0% SA. The OE line actually uses the correct "formulation matrix" of base oils composition and additives that would make it eligible for Dexos certification, but Amsoil chooses not to pay for it to be added. So yes, they meet the new LSPI requirements and the new turbocharger deposit tests. But they are not nor will not ever be "Dexos 1/Gen2" certified oils. Take that for what it's worth.
If Royal Purple can do it, Amsoil sure as heck can, at least for something like OE.
zuluplus30, I was wondering about the statement "Fortified with detergents that exceed the dexos1Gen 2 sulfated ash specification." in the PDS document. Thanks for the explaination. Sulphated ash is the overbased detergent sulfonates??? I know they have typically used a high amount of calcium detergents, and they must be getting away from that with all this LSPI concern.
I think it's possible that they could have kept fairly high calcium levels and quenched LSPI with a lot of ZDDP (since they are not API SN or GF5), high moly, and/or the use of ester base stocks. I don't think Amsoil was ever a big sodium user, so they didn't have to get rid of that. I guess we won't know until we see some VOAs or used oil analysis, which would still not tell us anything about ester content. The SS oils I looked at still had really high TBNs (12.5), but Molakule had shared with us previously that TBN can also be raised with organic additives.
Somebody correct me if I'm wrong, but it looks like the Mg detergents are not sulfonates (possibly salicylates), but the Ca detergents are sulfonates. Therefore, the 1% limit in dexos1 for SA (Sulfated Ash) would apply to the ~1,000 ppm (1%) Ca we see on UOA/VOAs ??? Many Gen1 dexos1 oils had very high Ca, around 2,000 ppm or so, meaning this 1% limit is for Gen2 only ???
I know you don't want too much sulfur in gasoline, since it forms too much sulfuric acid in the oil, and needs detergents to help neutralize those acids.
Here we see Amsoil exceeding the dexos1 SA limits. Whats the downside of this? I guess they do it to form a long-drain oil. But why would they need to if Mg detergents (I assume) are sans sulfur?
I had been reading "exceeds dexos1 sulfated ash specifications" as it was better than the dexos1 spec called for. I guess because so much literature says "meets or exceeds".
This is why Mobil 1 Annual Protection is the better choice. Since 2012 they've reduced the SA to .8. Mobil 1 Annual Protection is about the same price, but is fully certified and good for 20k miles.
