Originally Posted By: asharris7
That's what I am saying. Specs are different for each country....not saying it's a benefit or a negative. Specs are specs for a reason otherwise Honda, amongst others, would recommend the same oil vis regardless of origin.
Except the viscosity demands of the same engine are not going to change regardless of where it is located on the planet.
In other words, if a 0W-20 is good enough for Death Valley in the summer States side, it's good enough for the Australian outback.
What's different is that the advantages of the more expensive 0W-20 oil have been largely mitigated to the point that a cheaper more readily available light 5w30 conventional oil will do the job.
That said, 20wt oils are beginning to be specified in OZ but it will probably a very long time before you'll see it third world Africa.
